Paul8
Dec 18, 2017Aspirant
USB connected UPS
Had been using Cyberpower CP1500AVRLCD UPS for the last couple of years with this ReadyNAS thru a USB connection. Sometime this year with the firmware update now at 6.9.1, the USB connect to UPS app...
mdgm-ntgr
Dec 18, 2017NETGEAR Employee Retired
A UPS connected via USB should be automatically detected and used without needing any configuration.
Dec 18, 2017Guru - Experienced User
It should show up if you expand the UPS section of the power tab. I did that, and then clicked on the settings wheel, and see this:
- Paul8Dec 19, 2017Aspirant
Thank you for your suggestions. Just changed the UPS USB connection to the rear USB instead of the front and now it recognized it. Not sure why it does not work with the front USB.
