tonymazz31
Jan 20, 2025Aspirant
USB drive no longer recognised
I have been connecting the same external USB drive to my ReadyNAS to perform backups and now after the latest firmware update to 6.10.10 it is now no longer recognised. This now makes it impossible f...
- Jan 31, 2025
tonymazz31 wrote:admin@yallara:~$ df / -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 4.0G 0 100% /
Yes, this is the problem - a completely full OS partition.
Do you know how to find the largest files?
You can try moving into the top level folders - for instance cd /var
Then try this: du -hsx * | sort -rh | head -10
tonymazz31
Jan 31, 2025Aspirant
Hi Sandshark , thanks for your reply.
Can you please direct me to some instructions on how I can free up the space in the OS partition?
Jan 31, 2025Guru - Experienced User
The first step is to confirm that is the problem.
Is SSH enabled on the NAS?
