tonymazz31
Jan 20, 2025Aspirant
USB drive no longer recognised
I have been connecting the same external USB drive to my ReadyNAS to perform backups and now after the latest firmware update to 6.10.10 it is now no longer recognised. This now makes it impossible f...
- Jan 31, 2025
tonymazz31 wrote:admin@yallara:~$ df / -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 4.0G 0 100% /
Yes, this is the problem - a completely full OS partition.
Do you know how to find the largest files?
You can try moving into the top level folders - for instance cd /var
Then try this: du -hsx * | sort -rh | head -10
tonymazz31
Jan 31, 2025Aspirant
StephenB I logged on to SSH, here is the output;
Looks like this is the cause of all my issues?
admin@yallara:~$ df / -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/md0 65536 15363 50173 24% /
Jan 31, 2025Guru - Experienced User
- SandsharkFeb 01, 2025Sensei
Given the problems with the USB drive, it may not be the largest files that are the issue, but start there. If something did go wrong and files you intended to copy to the USB drive went to the mount point instead, there may be a large number of small files there. They would be located in a folder in the form /media/USB_HDD_X. Note that when you check there, make sure no USB drive is connected so you aren't looking at that drive's contents.
I've seen the problem with files going to the mount point posted (and resolved) here a couple times, but I don't believe anyone knows exactly how it happens. It's likely that the USB drive connection gets interrupted but the drive is not unmounted by the OS, but I have no idea why the OS would not unmount it unless it's just a matter of too little time.
- tonymazz31Feb 02, 2025Aspirant
Thanks StephenB for all your help, I deleted the syslog and daemon.log files in the /var/log folder and rebooted, OS partition no longer at 100%.
Apologies for assuming it was the latest firmware that was causing all my issues.
- StephenBFeb 02, 2025Guru - Experienced User
How much free space are you seeing now?
- tonymazz31Feb 03, 2025Aspirant
