Toronto_User
Dec 01, 2021Aspirant
USB drive shared from RN214 with DLNA - how to give access without login?
My ReadyNAS 214 (lastes OS) has a 3TB hard disk attached via USB 3.0. The disk contains video files. I want to make it available to users on my network using DLNA. On a DLNA device, I can see the USB...
- Dec 02, 2021Problem solved - all I had to do was turn “Anonymous Login” for the USB disk. Tout va bien maintenant.
Dec 02, 2021Guru - Experienced User
Toronto_User wrote:
On a DLNA device, I can see the USB drive but only at its root level. I can't gain access to any of the folders or subfolders without having to enter a user ID and password. I geta message telling me that this is required for SMB authorization.
It sounds like the "DLNA Device" isn't using DLNA.
Can you give us more info on what it is?
Toronto_User
Dec 02, 2021Aspirant
- StephenBDec 02, 2021Guru - Experienced User
Toronto_User wrote:
Problem solved - all I had to do was turn “Anonymous Login” for the USB disk. Tout va bien maintenant.Still, your solution means the player wasn't using DLNA - it was using SMB.
