ILS_Network_Adm
Feb 03, 2014Aspirant
USB Drives Not Showing Up
Hello Forum, Here at InterLab Supply we have a Netgear ReadyNAS Duo that we use as our File Server. We have, or should I say HAD, a backup protocol that would backup everything on the File Server t...
vandermerwe
Feb 03, 2014Master
Are you sure you have Duo v2?
http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
What firmware are you running?
Was the old USB disk umounted properly or just unplugged, failing to in mount a USB drive can certainly cause problems like this.
Was the 3 tb formatted before attaching and if so what formatting?
Have you rebooted the NAS and tried attaching the drives?
