OldDuffer's avatar
OldDuffer
USB drive shows only one partition
Just thrown away my hideous BT Home Hub 3 and replaced it with a Netgear D6400, latest firmware installed (V1.0.0.56_1.0.56).  All seems well except for the USB-connected 2TB Western Digital drive I've been using for a number of years (if I recall correctly it worked with my previous Netgear ADSL device too).
Simple problem: there are three partitions on the drive but I can only see one.  Wasn't a problem for the crappy BT device.
I've seen some posts suggesting it may be a genuine issue with the Netgear devices, ie. there don't appear to be successful resolutions to this missing configuration.
Can I configure my way out of this or do I have to combine all of the partitions into one?
Thanks,
Keith
    • OldDuffer's avatar
      OldDuffer
      Hi,
      There's a primary partition and two logical partitions, all formatted as FAT32.
      Thanks,
      Keith
      • aalexandrebeta's avatar
        aalexandrebeta
        Master
        The only answer I am thinking about is that the device is booting only on one partition and on the primary and do not recognize the logical ones.
        I may be wrong!
  • It's not a boot device, it's only used for storage. I can only see the primary partition through ReadyShare, not the logical ones.
      aalexandrebeta
      Master
      I know this is not a boot device but the way the unit is booting on the drive it only sees the first partition and blind to the other logical ones.
  • Thanks for your comments and interest, but I'm not sure where this is going: I know it only sees the primary, that's the problem.
    The question is whether more recent Netgear kit can or should recognise multiple partitions on a USB drive? My old ADSL router could (I think it was a DGND3300) and the lousy BT kit could ... why not the D6400 which is way superior in all other respects.
    Thanks.
      aalexandrebeta
      Master
      Do you have an USB key, make an experiment doing 2 partitons and see if the 2 are recognized or only one?
  • That was a really good suggestion. I eventually got a USB thumb drive set up with two partitions and ReadyShare does actually see both: fantastic news!
    I think the two non-primary partitions may be Extended rather than Logical (they're reported as logical by the EaseUS tool I'm using). I may be able to convert from Extended to Logical in which case job done! Let's see.
    Thanks.
      aalexandrebeta
      Master
      I am glad that I could eventually helped you to partially solve your issue!
      Thumbs up!!
        OldDuffer
        Success!  But I'm not 100% sure why.
        Having spent Sunday backing up the three partitions on the USB drive, last night I converted one of the extended partitions to logical in EaseUS Partition Manager and confirmed that the content was as I expected on a desktop.  I then plugged the drive into the D6400, expecting to see the primary and one of the non-primary partitions ... and lo! ... I could see all three.
        I'm currently running with an apparent mix of three types of partition but it seems to be quite happy, I have the primary, a logical and the unconverted extended partition.  I don't intend to tinker further, it's working for my purposes.
        I reckon this is solved: thanks for your help!
        Keith
