TehDags
Jul 31, 2019Tutor
USB Recovery
Model: RNRX4410-100NAS (2100) Looking for the process to boot this particular model to the USB for reccovery. Before posting links, please make sure it has the information. I've looked over a...
- Aug 05, 2019
Hopefully this will help more people. Even though this model is a rackmount. The reset button will only boot you to the boot menu. The "Backup" button is the button you want even though it has a reset button. Holding the backup button at power on for 10-15 seconds will cause it to boot to the USB.
Sandshark
Aug 01, 2019Sensei
So if this process is done on a rackmount unit without a VGA connection, there is no indication using the NAS LEDs? You must rely on the USB device's access LED (assuming it is even equipped with one) to let you know anything is happeneing? I can say nothing more than "poor design" and hope the user the best in performing this operation.
I do wonder, however, what drives the decision to do a USB recovery. It's typically a last resort fix and can make things worse when done under the wrong circumstances..
Aug 01, 2019Guru - Experienced User
I'm wondering that also.
Perhaps TehDags can follow up with more information on the problem he is trying to solve.
