mwilliams6275
Apr 27, 2016Aspirant
Using Amazon Echo To Access ReadyNAS DLNA
Currently I access the ReadyNAS DLNA server via my blu-ray player, which is attached to my TV (obviously) and my home stereo system. I'm looking at the Amazon Echo/tap devices as an alternative, prim...
- Apr 27, 2016
JennC wrote:
If it is a DLNA compliant product then it will work with the ReadyNAS.
I think the challenge here is that it not DLNA compliant. Though I don't own one, so I can only go by what I read.
There is an Alexa app (houseband) that can control the JRiver Media Center software. The media center can then control Sonos speakers - https://www.youtube.com/watch?v=NPsOKhC7V4g
But that doesn't involve the NAS directly, and AFAIK it isn't a general DLNA solution. There isn't any hint that houseband can work with plex for instance.
JennC
Apr 27, 2016NETGEAR Employee Retired
Hello mwilliams6275,
If it is a DLNA compliant product then it will work with the ReadyNAS. Now to control the product that allows you to use your mobile or smart phone, I think that already depends on the app that you will use on the phone. How its interface works and display things.
- StephenBApr 27, 2016Guru - Experienced User
