mwilliams6275
Apr 27, 2016Aspirant
Using Amazon Echo To Access ReadyNAS DLNA
Currently I access the ReadyNAS DLNA server via my blu-ray player, which is attached to my TV (obviously) and my home stereo system. I'm looking at the Amazon Echo/tap devices as an alternative, prim...
- Apr 27, 2016
JennC wrote:
If it is a DLNA compliant product then it will work with the ReadyNAS.
I think the challenge here is that it not DLNA compliant. Though I don't own one, so I can only go by what I read.
There is an Alexa app (houseband) that can control the JRiver Media Center software. The media center can then control Sonos speakers - https://www.youtube.com/watch?v=NPsOKhC7V4g
But that doesn't involve the NAS directly, and AFAIK it isn't a general DLNA solution. There isn't any hint that houseband can work with plex for instance.
JennC
Feb 22, 2017NETGEAR Employee Retired
Hello mwilliams6275,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
