Gilfammedicine
Feb 18, 2019Aspirant
Using Kingston SSDs in my RN212
I am using two Kingston 480 GB SSD's. These SSD's weren't on the list of accepted hard drives for my NAS. Is there a reason they won't work for the RN212? It doesn't make sense why they wouldn't be c...
- Feb 19, 2019
The ReadyNAS HCL list is actually not updated regularly, we have actually requested for it to be updated. Your SSD should work with your RN212 provided that the SSD does not have any issues to start with. Also, make sure that the series you have is suitable for NAS use.
Updating your NAS is also a good idea. Hope this helps!
Regards
Gilfammedicine
Feb 19, 2019Aspirant
So far the Kingston's are working and healthy. The reason i asked is because i am having issues with speed and slow navigation (like 10 minutes to open a small PDF). I am just rulling our possible causes. My fear was that some compatibility issue with Kingston was causing it since it wasn't on the list. But because it is reading it fine and it works great (at times) i don't think the issue is with my SSD's. Any thoughts?
Marc_V
Feb 19, 2019NETGEAR Employee Retired
What firmware is installed on your RN212? Are you using it as a single volume?
- GilfammedicineFeb 19, 2019Aspirant
I have the latest 6.9.5 Firmware. I have two 480GB SSDs in Raid 1.
- itachi2Feb 19, 2019Tutor
You may want to try updating firmware on the drives themselves - you'lll probably need a PC with a spare SATA connection to hook the drive up to temporarily.
V300, UV500, KC400, E100, E50, S200, HyperX Savage, and Fury have firmware updates available. I only looked at drives already in SATA form factor, so if you're using M.2 with adapters or some such, check Kingston's support for those.
https://www.kingston.com/us/support/technical/category/ssd
If you mess with the drives, make sure to power off the NAS first (!)
Anyway, it might help with timeouts and compatibility - check the notes if they posted them for the updates...
