kcallis
Jul 04, 2012Aspirant
Using RAIDar to change IP address
Is there anyway to use RAIDar to change the IP address of my NV+? I just changed the IP address of my router, and I need to change the IP address and gateway information for the NV+. Is there a simple...
kcallis
Thanks, I forgot about the OS reset, and of course now that I have that going, life would have been so much more easier if I had run across you post and just changed my ip my my laptop. It has been awhile... What is the default user/pass when doing an OS Update?
*** Strike that, I now remember... Thanks for the earlier pointer...
