civean
Aug 07, 2017Aspirant
Using selective sync with Dropbox
Hi, now that the Dropbox plugin seems to work fine, we have enabled sync to Dropbox for our main development share. We have around 150 GB data and sync this to a 1 TB Dropbox Pro account. We also us...
civean
Hi,
thank you for an informative response!
I believe you are correct, restricting access to the snapshots folder will prevent dropbox from syncing. However, we are currently relying on access to the snapshots for users to retrive earlier versions of files, retraining them to use windows built in previous versions is not ideal. If that is the only way around this issue we might have to, however - it is important for us (regulatory reasons) to have access to unlimited versioning back to the file creation date, in addition to the other layers of backup we have on and off site. If I understand your second variant correctly, we would have to use a limited retention period, which is not ideal. I will investigate tomorrow whether any of these solutions will work for us.
Christer
Aug 07, 2017Guru - Experienced User
The months setting will take values up to 828 months (69 years), if you try to go higher it will misbehave. Seems to me that should be high enough for any practical purpose..
BTW, you are losing some versions with the "SMART" snapshots due to the thinning.
