SuperNASman's avatar
SuperNASman
Using share quotas to prune old files
Hello, I wanted to know if there is a way to use a share quota to delete old files.   For instance, is it possible to set a 1 TB quota on a share, and have the NAS start deleting files, starting wi...
  • Danthem's avatar
    Nov 30, 2016
    Hey SuperNASman,
    There's no such built in feature but I'd like to point you in the direction of an old post I made in a thread requesting something similar.
    First of all please note that incorrect SSH usage may result in rejected support (until you factory default).. The script below is not official and is used at your own risk.
    https://community.netgear.com/t5/Using-your-ReadyNAS/cron-job-with-shell-script/m-p/971648#M91936
    You could modify the script to include an if statement checking if used space > X then go ahead and delete files older than Y, but I'll leave that up to you.
ProSupport for Business
