vakubhai
Feb 11, 2017Aspirant
utorrent on rn314
Have installed utorrent on readynas. i am also able to download torrents. But am clueless on where are the files. something to do with SSH?? Please help on the same. dunno how to find t...
FramerV
Feb 13, 2017NETGEAR Employee Retired
Hi vakubhai,
I do not have uTorrent on a NAS but I do use it on a PC so it might be the same.
You would normally have an option to set where the downloaded torrents would go to. Try checking the settings of the uTorrent app (if any).
You could check this link as well:
FramerV
Feb 17, 2017NETGEAR Employee Retired
Hi vakubhai,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- vakubhaiFeb 17, 2017Aspirant
Ofcourse its not resolved.
below is the settings window of utorrent app.
i cant find the directories.
CAN SOMEONE HELP??
- StephenBFeb 18, 2017Guru - Experienced User
If you access the NAS data volume with admin credentials, there is a hidden .apps folder. That is a different path to \apps.
So you'd access \\nas-name\data\.apps\ut-server ...
You are better off creating a share for this, and configuring it in utorrent as /data/sharename/ ...
- Mar 10, 2018Retired_Member
