chopin70
Apr 27, 2017Virtuoso
V+12 voltage in enclosure Internal is out of spec. (10.72 V).
I am getting since yesterday this error message, repeatedly: V+12 voltage in enclosure Internal is out of spec. (10.72 V). Nothing changed, no recent update, I am running 6.6.1 since near 4 mont...
- May 06, 2017
chopin70 wrote:What is the lowest voltage that will cause corruption of data?
Unfortunately, that's most likely impossible to tell for sure. If the voltage is out of spec, then it's a problem, even if it appears to be working. If it's not out spec, then it should work without issue.
Now, what's out of spec? Good question. If you really want to explore in that direction, I would first try to measure the actual voltage as Sandshark suggested. If you consider PSU tolerance, then 11.4V seems to be the minimum 'in spec': https://www.lifewire.com/power-supply-voltage-tolerances-2624583
Though I do not know for sure what is the minimum voltage on the 12V that the different components would "accept", I personnaly wouldn't feel comfortable if it's not within the standard PSU tolerance. Then the components are not designed to work it, and you may encounter random issues. Not exactly what you want with your data storage.
Sandshark
Apr 27, 2017Sensei
Assuming that's on the Ultra2 you have listed for your devices, it sounds like a bad power brick. It's a standard 12V, 5A brick. You can buy them lots of places, you may even already have one for another device.
chopin70
Apr 28, 2017Virtuoso
Ok, many thanks, I will look at my existing external power bricks if I already have one spare and give a feedback
And yes, it is on my old Ultra 2 that works perfectly for now.
Ok, I don't have any such one at home. When shopping online, how can I be sure the output plug is the same and will fit ?
Netgear doesn't sell such spare parts ?
- StephenBApr 28, 2017Guru - Experienced User
Unfortunately they don't.
There are part numbers on the label, googling them will help.
You can also just look for a replacement ultra-2 brick. That will usually turn up some results: https://www.amazon.com/Netgear-ReadyNAS-replacement-supply-adaptor/dp/B00KT4GDEE
- chopin70Apr 28, 2017Virtuoso
Is there a way to know if it is the sensor issue rather ?
Otherwie, thank you all,
I ended up googling for Netgear NU60-H120500-I1
As I live in Europe, I ordered this one
Will give a feedback as soon as it comes. Hope it will fix my V+12 warnings...
- chopin70May 06, 2017Virtuoso
The new brick did not fix my issue
I get low voltages as of 10.40V !
Have I to worry about it, sensor issue ? Power issue somewhere else ?
I'd really appreciate some help
