Rimbalza
Jun 20, 2018Aspirant
Very poor performance on iSCSI
Starting situation: Windows 2012R2 with MPIO with 2 gigabit adapters. RN316 with 6.9.3, 6 Drives full.
When a backup starts from the other NAS (same model) to this one (both DR or rsync) the iSCSI ...
Rimbalza
Just to add: the volume is not compressed
hezner1
Jun 21, 2018Tutor
I don't know if it would help you in your situation but we found that after we upgraded to 6.9.3 OS we had very slow save speeds. Strict sync had been disabled in the 638 OS but is enabled by default in the 6.9 OS. When we disabled the strict sync that problem was resolved. We are not using iscsi so I don't know if this is your issue but It is an easy setting to change and might be helpful. Here is the link to my post about the issue that references others who researched the problem originally. https://community.netgear.com/t5/ReadyNAS-in-Business/Slow-saves-for-Revit-2018-after-OS-upgrade-from-6-8-1-to-6-9-2/m-p/1557861#M8003
- RimbalzaJun 21, 2018Aspirant
Thanks for your reply, but I'm not using SMB and tested sync writes on and off ono iSCSI too with no success.
Today I'm trying to run a backup and I get horrible performance and not constant. In the graph below up is IOPS and down Network.
It goes up, then drops and then slowly gets better, but nothing acceptable.
We'll dump Netgear stuff asap...
- mdgm-ntgrJun 21, 2018NETGEAR Employee Retired
What about CoW, bit-rot protection and snapshots? Have those always been disabled on this LUN?
Is the LUN thin/thick?- RimbalzaJun 21, 2018Aspirant
You can find the relevant info in the first post.
BTW, no CoW and compression, thick LUN.
Edit: and no snaps
Please send in your logs (see the Sending Logs link in my sig).
I would like to send, but since I stopped the backup the device is hung also in the web interface or very very very slow...
I'm currently stuck on http://mydevice/dbbroker after clicking download...
