Geeks_Alex
Oct 21, 2017Tutor
Very slow copy with SMB
Hello,
I have very slow copy with SMB since 6.9.0 : 9 Mo/s. Normaly it's 90-100 Mo/s
Tested without SM3 Encryption. It's the same.
Anyone can't help me. Someone have the same problem. Can y...
- Oct 24, 2017
Just to say the encryption on SMB3 is to difficult for ARM on RN102 and that why SMB use all the CPU ressource with very slow copy.
Geeks_Alex
Oct 21, 2017Tutor
I have very hight CPU on the NAS : 90%
- KardanoOct 22, 2017Luminary
I can confirm that.
All my backup jobs which took data from or to windows share are EXTREME SLOW.
on FW 6.8.1:
Backup Job Name: UT Backup Backup Job Type: Incremental Protocol: cifs Backup Source: [remote:cifs]///192.168.77.100/uTorrent Backup Destination: [Backup]/uTorrent Backup Start Time: Fri Oct 20 2017 0:05:08 Backup Finish Time: Fri Oct 20 2017 0:05:09 Backup Status: Success Copy File resume.dat Copy File resume.dat.old Copy File settings.dat Copy File settings.dat.old
On FW 6.9.0 that job is running for hours a still does not complete.
Client or source of shares are 2 diferrent Windows 7 PC's.
There is no high CPU usage on NAS.
There is someting terribly wrong with FW 6.9.0
tried this:
Disable Opplocks - no change
Disable SMB Encrypt - no change
- mdgm-ntgrOct 22, 2017NETGEAR Employee Retired
What are the full settings for the backup job? What kind of SMB backup is it?
Moved this thread. The Beta section is strictly for questions about beta firmware.
full settings for backup job:
Windows/NAS (Timestamp) -> share
Source:
Type: remote - Windows/NAS (Timestamp)
host: defined as IP
path: share On PC
(test connection is OK)
Destination:
share on NAS
Schedule
every 24 hours 0:05-0:05
Options
scheduke full backup: first time
On completion send: status and errors
Remove selected contents of backup destination before backup - NOT selected
After backup is complete, change ownership of files.... - NOT selected
last log entry for this job: when was complete, FW 6.8.1
Now is job showing status: In Progress
running for about 5 hrs.....
same thing happening (not wokring) for jobs which are:
share -> remote: Windows/NAS (Timestamp)
last log entry for this type of job: when was complete, FW 6.8.1
Backup Job Name: Documents_Personal_Cajo7n Backup Job Type: Incremental Protocol: cifs Backup Source: [Documents]/Personal Backup Destination: [remote:cifs]///192.168.77.2/Documents/personal Backup Start Time: Thu Oct 19 2017 22:05:07 Backup Finish Time: Thu Oct 19 2017 22:05:09 Backup Status: Success Copy File Rozpočet 2017.xlsx Copy File Vydaje 2017.xlsx Copy File Vydaje Porovnanie.xlsx
All Rsync jobs are OK.
are these setting sufficient for you?
NAS is RN204.
All SMB jobs was OK until updating FW from 6.8.1 to 6.9.0.
After updating nFW to 6.9.0 no SMB/cifs job was completed. 1st described job was running for 20 hrs but not completed. After cancellation of jpb (i hoped, tat is some kind of error and it block another jobs) noting is writed on jobs log.
