SoundmanArt
May 16, 2019Apprentice
Very Slow Read/Write and Time Machine Backup
I know this has been written about for many of the ReadyNAS servers, but I haven't seen it for exactly the same issues I'm having.
It's slllllloooooowwwwww. Get the point. It will take weeks ...
- Jun 10, 2019
I thought I'd close this discussion with the final outcome.
I did open a ticket with Netgear. They did replace the unit. But it was still dreadfully slow. It must be something in their OS that makes writes of small files dreadfully slow. I even tried it on a high end Windows PC. Same slow speeds.
And I did once again verify that I did not have these slow speeds with an old Buffalo NAS that I still had lying around. I got between 30-45 MB/second with that vs the 1 MB/second with the Netgear NAS.
So I ended up purchasing a 5-bay USB-C drive enclosure to connect to my Mac. Of course, I get blazing speeds with this.
For now, I've put some old 3TB drives into the RN3138 and I've relegated it to be a backup NAS for my small computers.
If/when they ever fix this issue, I might come back. But I don't expect that to ever happen.
VERY DISAPPOINTING!
SoundmanArt
May 26, 2019Apprentice
Ok. I ran it 2 ways on a MacBook Pro. Both tests ran for 3 hours.
180 GB folder
MacBook Pro -> Mechanical Drives = 15.59 GB
MacBook Pro -> SSD = 15.60 GB
It starts up fast on both, gettting the first 1-2 GB done in just a couple of minutes. Then it comes to a halt.
May 27, 2019Guru - Experienced User
180 GB folder
Certainly slower than it should be.
Perhaps try connecting the NAS directly to the MacBook??? That would require temporarily assigning a static IP address on both.
- SoundmanArtMay 27, 2019Apprentice
Did that with the NAS and the MacBook Pro connected directly. I got the exact same amount copied -- 15.60 GB in 3 hours.
As with all of the other copies, it started out like gangbusters. And then came came to a screaching halt.
So??? Is there a problem with my NAS that needs to be sent it under warranty? Is there insufficient RAM?
This is crazy!
Art
- StephenBMay 27, 2019Guru - Experienced User
It has 4 GB, which should be enough.
If it's still connected can you take a look at the network stats in the log zip?
I had disconnected it. But here's the log file.
Were you using eth0 or eth1?
ETH0. ETH1 was disconnected while I was doing the copy.
- StephenBMay 28, 2019Guru - Experienced User
Ok. And no errors related to ethernet were reported in the log.
SoundmanArt wrote:
I've changed hard drives, cables, switches. It's slow with ALL of my computers, not just one. I've tried Jumbo Frames and normal size frames. I've tried with/without antivirus.
I have no idea where to look now.
I'm certainly running out of ideas.
One or two more though:
- do you have file search enabled? If so, disable that.
- If you are running the new audit feature in 6.10.0, then disable that too.
Keep strict sync off (and test with "vanilla" SMB, not TimeMachine). And use with the new SSD volume
Not sure if the Mac will connect to the NAS if you turn SMB transport encryption off. But if it will, try disabling that too.
Maybe also disable any services you aren't using (for instance NFS), and turn off all apps.
BTW, I've been assuming that you aren't using the volume encryption feature of the NAS. Is that correct?
- SoundmanArtMay 28, 2019Apprentice
I'm running a plain vanilla system. The only services running are SMB, UPnP, HTTP and HTTPS. Currently, I even have antivirus turned off.
File search is also off.
No apps are installed.
SMB3 Transport Encryption has 3 options -- Enable, Desired and Required. Right now it is Enabled.
Audit is also off.
I don't see where you turn volume encryption on or off.
It's off by default (and you'd certainly know if you were using it).
So it's not
- the load on the NAS (and even if it is encrypting the transport, it should be capable of faster speeds with small files).
- the disks since you switched over to ssd
- a volume issue, since the switch to ssd created a fresh volume
- cabling, since you replaced that (and aren't seeing issues with ethernet errors)
- your infrastructure, since direct connect gave the same performance
- the mac itelf, since you've tried more than one PC.
Looking once more at network_settings.log, you still have ipv6 enabled. That can create performance issues with Windows (especially when ipv6 isn't enabled in the router). I don't know if that's also an issue with Macs - but you probably should disable ipv6.
After that, I am out of ideas on things to try. So if that also makes no difference, then perhaps see if JohnCM_S or Hopchen are willing to analyze your full log zip (they might possibly see something there).
If you are conversant with linux, you could log in with ssh, and see if top (or one of the other linux tools) gives you any clues on where the performance bottleneck is.
I have turned off IPV6 and will try another copy. If I see it bogging down again, I will just abort it instead of running it the entire 3 hours has I have been.
I used to be very comfortable with Unix, but it's been many, many years. Without instructions, I doubt I could figure out top.
Will the other 2 gentlemen see this link because you added their names or do I need to contact them individually?
The @ should give them a notification. But it does no harm to send them a private message and ask for their help. Use the envelope icon on the upper right of the forum for that.
Copying without IP6 produced the same results.
I was afraid that would be the case. Then I am out of ideas.
Well thanks for trying. I did PM the other 2 gentlemen. If nothing soon, time to place a warranty claim I'm afraid.
- SoundmanArtJun 10, 2019Apprentice
VERY DISAPPOINTING!
