SoundmanArt
May 16, 2019Apprentice
Very Slow Read/Write and Time Machine Backup
I know this has been written about for many of the ReadyNAS servers, but I haven't seen it for exactly the same issues I'm having.
It's slllllloooooowwwwww. Get the point. It will take weeks ...
- Jun 10, 2019
I thought I'd close this discussion with the final outcome.
I did open a ticket with Netgear. They did replace the unit. But it was still dreadfully slow. It must be something in their OS that makes writes of small files dreadfully slow. I even tried it on a high end Windows PC. Same slow speeds.
And I did once again verify that I did not have these slow speeds with an old Buffalo NAS that I still had lying around. I got between 30-45 MB/second with that vs the 1 MB/second with the Netgear NAS.
So I ended up purchasing a 5-bay USB-C drive enclosure to connect to my Mac. Of course, I get blazing speeds with this.
For now, I've put some old 3TB drives into the RN3138 and I've relegated it to be a backup NAS for my small computers.
If/when they ever fix this issue, I might come back. But I don't expect that to ever happen.
VERY DISAPPOINTING!
SoundmanArt
May 28, 2019Apprentice
I have turned off IPV6 and will try another copy. If I see it bogging down again, I will just abort it instead of running it the entire 3 hours has I have been.
I used to be very comfortable with Unix, but it's been many, many years. Without instructions, I doubt I could figure out top.
Will the other 2 gentlemen see this link because you added their names or do I need to contact them individually?
May 28, 2019Guru - Experienced User
The @ should give them a notification. But it does no harm to send them a private message and ask for their help. Use the envelope icon on the upper right of the forum for that.
- SoundmanArtMay 28, 2019Apprentice
Copying without IP6 produced the same results.
- StephenBMay 28, 2019Guru - Experienced User
I was afraid that would be the case. Then I am out of ideas.
Well thanks for trying. I did PM the other 2 gentlemen. If nothing soon, time to place a warranty claim I'm afraid.
- SoundmanArtJun 10, 2019Apprentice
VERY DISAPPOINTING!
