kirkfrey
Sep 29, 2015Aspirant
VERY slow rebuild - 780 hours
I finally sorted out the OS drive full and got repalcement drives for 2 failing drives 1 had ~600k RRE's the other had nearly 7M RRE's!). When I replaced the first drive it rebuilt in a "normal" amo...
kirkfrey
CIFS, NFS, FTP, HTTP, HTTPS, Rsync (no changes in months to anything
Dnsmasq and CrashPlan
Nope, I was letting it sit to rebuild. no load (I am now copying off to another device in case another drive is failing)
No other drives with any RRE's
RAIDiator 4.2.22 (no changes)
other than replacing the failed disk, no changes.
kirkfrey
Sep 30, 2015Aspirant
After having run all night it is still running slow and only 1% done:
Recovery 1% complete, Time to finish 729 hr 37 min, Speed 1100 KB/sec
Thoughts?
- StephenBSep 30, 2015Guru - Experienced User
Did you upgrade java on the pro (and change javacommon in crashplan's install.vars)? Or did you just clear the failed upgrade files? You might want to ssh in again, and make sure the OS partition remains ok (crashplan will continue to attempt auto-upgrade, and also they pushed 4.4.1 a couple days ago)? You can also try running top to see if something is really loading down the NAS.
Are you seeing any bad signs in the SMART stats?
- kirkfreyOct 01, 2015Aspirant
Shoot, thought I replied.
I upgraded but didnt change java variables - how do I do that?
i've re-deleted the upgrade files.
No smart errors on any drive
Top shows - nothing really run away I think but not sure what a "normal" top looks like
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
9942 nobody 20 0 26712 15m 13m S 20 0.4 15:12.74 smbd
867 root 20 0 0 0 0 D 10 0.0 56:10.34 md2_raid5
2068 root 20 0 0 0 0 S 7 0.0 24:47.82 kworker/0:2
30645 admin 20 0 13708 4780 2108 D 3 0.1 0:03.39 proftpd
407 root 20 0 0 0 0 R 1 0.0 4:21.31 kswapd0
16440 root 39 19 1205m 125m 7644 S 0 3.2 1:16.53 java
1 root 20 0 2068 652 552 S 0 0.0 0:02.04 init
2 root 20 0 0 0 0 S 0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0 0.0 0:01.23 ksoftirqd/0
4 root 20 0 0 0 0 S 0 0.0 0:00.15 kworker/0:0
6 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/0
7 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/1
9 root 20 0 0 0 0 S 0 0.0 0:01.00 ksoftirqd/1
11 root 0 -20 0 0 0 S 0 0.0 0:00.00 khelper
158 root 20 0 0 0 0 S 0 0.0 0:00.22 sync_supers
160 root 20 0 0 0 0 S 0 0.0 0:00.00 bdi-default- StephenBOct 01, 2015Guru - Experienced User
in /usr/local/crashplan/install.vars there is a variable called JAVACOMMON
Enter "which java" and note the path. Then set JAVACOMMON to that path.
