Tinyhorns
Aug 21, 2016Apprentice
Very slow Reshape
Hi, I have an external cabinet with 3 disks (EDA500), added a 4th, and now the reshape has begun. but its slow as hell. 15618353664 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]...
- Aug 22, 2016
mdgm wrote:
Those are high capacity disks. I think the resync time is reasonable for the EDA500.
At 13 MB/sec, it will take about a week to resync. Since performance stalls during the resync, and if anything goes wrong during the week there is risk of data loss.
Even if that's the best the system can do, from a user perspective it isn't great.
Granted the port multiplier will constrain performance, but 13 MB/sec does seem very slow when you are taking about disks that are at least 10x faster than that.
mdgm-ntgr
Aug 21, 2016NETGEAR Employee Retired
What capacity disks are these?
The EDA500 uses a port multiplier so the performance is lower than for disks in the main chassis.
- TinyhornsAug 22, 2016Apprentice
Hi,
The disks are 8TB WD Red,
I can understand that performance is a bit slower on the external port, but 13-15mb/sec? thats almost floppy-speed :)
// T
- mdgm-ntgrAug 22, 2016NETGEAR Employee Retired
- StephenBAug 22, 2016Guru - Experienced User
