Soulkeeper
Nov 28, 2012Aspirant
Volume expansion failed - 2790 GB * (6-1) = 3690 GB
I have just set up a ReadyNAS Ultra 6. Loaded with 6 x Seagate ST3000DM001-9YN166 drives. RAID5. RAIDiator 4.2.22 This doesn't look right. What can I do to correct it? I clicked "Expand...
mdgm-ntgr
Nov 28, 2012NETGEAR Employee Retired
Jumping from 4.2.15 to 4.2.22 should work fine. THe problem here is adding 3TB disks before updating to 4.2.16 (or later). All Soulkeeper needs to do is backup the data already loaded onto the device and do a factory default.
