GeoffB1
May 28, 2013Aspirant
Volume expansion failed-many times
I have a Ultra 6 that had 3 X 3TB WD Red drives in it. I added 3 more. The drive expanded to include the 4th drive, but didnt seem to recognise the other 2. Then it did, but said that the 5th drive ...
GeoffB1
I have not done a factory reset at all. The first build (at factory default) was 3X3TB, and the only addition was the 3X3TB extra. At the time of the addition I did not realise that I would max out at 8TB addition, but I do now. The problem that I am having is after only 1X3TB. On the smart logs, each disk says "SMART overall-health self-assessment test result: PASSED" & "SMART Error Log Version: 1 No Errors Logged". I should say that the Western digital scan showed 4 partitions - 2 very tiny ones, but 2 good sized ones. I assumed that these two main partitions were where the ReadyNas was doing the expansion. If that is so, then it was about 25-30% through the disk.
