LucDV
Oct 13, 2014Aspirant
volume expansion on ready NAS ultra
I have on my Ready NAS ultra 6 bay with 3 HD's of 2TB (initial install). They were installed in X-raid.
Afterwards, I installed 3 extra volumes of 4 TB at different timings, the last one a few days ago.
This last install didn't increased the available volume and overall volume is still limited at 9255GB while global volume of installed HD's is 18TB.
I read the overall volume is limited at 14 TB. Is this correct? In this case, can I simply remove two 2 TB disks? Are there other alternatives to obtain a maximum usable storage capacity?
A factory reset seems no solution for me since I have no possibility to first back-up alle data.
Thanks for helping me out with this topic.
Kind regards
Kind regards
- mdgm-ntgrNETGEAR Employee RetiredBut you said you added three 4TB disks?
Have you tried a reboot?
I think adding a third 4TB disk has limited what expansion you can get. - LucDVAspirantYes, I've done a reboot. All 6 disks are allocated for 1858GB(2TB disks) and 3721GB (4TB disks). Global allocated stayed unchanged on 9255GB.
It seems to me that after installation of the 5th disk a volume of 11,2 TB should have been available, which was not (then also 9225TB)
I installed 3 4TB disks at different timings (months).So, after installation of the second 4 TB disk, my available should have been 11,2 TB. Which was not (9,225TB) - vandermerweMasterI'll just repeat what mdgm has already said several times. The 9.2 TiB is the correct capacity after the 2nd 4 tb disk was added.
When you add the 3rd 4tb disk the volume size is theoretically 12.8 TiB which takes you over the 8TiB limit. NO expansion takes place because of this. The Nas can't partially expand to the 11.6 limit.
You will need to factory default.
See http://ram.kossboss.com/xraid/ - LucDVAspirantOK.
Other question. Can I safely replace the three 4TB's disks then by 2TB's disks, one at the time. Must I do the replacement with power off? (In this case, I can use the 4TB disks for back-up before going to a factory default) - mdgm-ntgrNETGEAR Employee RetiredTo revert to smaller capacity disks a factory default would be needed.
