straff
Jan 20, 2019Aspirant
Volume Maintenance scheduled jobs stopped running
Hi. I have scheduled maintenance jobs (see attached), which have run happily since I installed the ReadyNAS, but for a few months now they have not been running (log attached). I can't put a precise ...
- Jan 21, 2019
Well, that (firmware update) seems to have done the trick - I set a schedule for 11 GMT today and it's currently in progress.... fingers crossed. Thanks for the input
Jan 20, 2019Guru - Experienced User
What firmware are you running?
I suggest rebooting the NAS if you haven't tried that. Maybe adjust the schedule to run the scrub (or file system check) tomorrow first.
