tyrrminal
Jul 21, 2023Aspirant
Volume missing following crash and rebuild
ReadyNAS NV+ v2 running RAIDiator 5.3.12 When I woke up this morning I found that my NAS was turned off. I turned it back on and it immediately started an array rebuild (4x3 TB Toshiba disks, X-R...
Jul 22, 2023Guru - Experienced User
tyrrminal wrote:
I have ssh access, but I need guidance for how to go about recovering this.
First enter
cat /proc/partitions
Check that all disks are shown.
Check the disk health for thost disks using smartctl
smartctl -x /dev/sda
smartctl -x /dev/sdb
smartctl -x /dev/sdc
smartctl -x /dev/sdd
Look for
- errors in the smart stats (pending sectors, reallocated sectors, etc)
- failures in the SMART Extended Self-test Log section
- errors in the SMART Extended Comprehensive Error Log
Then
cat /proc/mdstat
and see what RAID arrays are assembled.
Last try
mdadm --examine /dev/sd[a-d][3-6]
You can post back with the output of these commands.
