readynas_user99's avatar
Aug 30, 2015
Volume not expanded after adding higher capacity disks
Hi, I have a ReadyNAS NV, and I've been running X RAID with 4 x 1 TB Disks.    Recently, I've been replacing the disks 1 by 1 with 2 TB disks.    After last night, I finally now have 4 x 2 TB Disks in X RAID configuration.   However, in Frontview, under the Volume Settings, I noticed that ReadyNAS is not taking advantage of the new capacity, and it's still showing that I have capacity of about 3 TB.    I thought ReadyNAS would be smart enough to detect that I now have 4 x 2 TB disks, then the total volume should be expanded to 6 TB instead of 3 TB.
I remembered I've done this in the past while upgrading from smaller capacity disks to the 1 TB disks and it worked.    What do I need to do to make get ReadyNAS to recognize the extra capcaity?
Thanks.
  • StephenB's avatar
    If the volume looks synced, try rebooting it.
    What firmware are you running?
    • readynas_user99's avatar
      readynas_user99
      Reboot seemed to have done something.   I now see in the Volume page of Frontview showing me the right amount of disk space (~2TB) are allocated on each disk,  but the overall capacity of the NAS hasn't changed.   It is still stuck at 3TB, not 6 TB as I was expecting.
      I then saw this error in the log: "Disk capacity expansion error. resize2fs".   After googling this for a while, this seems to be a known problem with upgrading to 2 TB drives in ReadyNAS:  https://community.netgear.com/t5/Using-your-ReadyNAS/Disk-capacity-expansion-error-resize2fs-Readynas-NV-F/td-p/653186
      Am I now stuck with no option but to initialize my ReadyNAS from scratch?   What a painful process trying to move from 4x1 TB to 4x2 TB.   Had I known this, I would have reconsidered.   I now have spent over $300 on new disk drives, and still not getting the capacity that I wanted.    I've always been a ReadyNAD fan, but this is got to be the biggest disappointment with this this product.
      • StephenB's avatar
        Let's first confirm that this is the issue -
        Please download the logs from FrontView > Status > Logs > Download All Logs.
        Look at system.log and search for "block size".  Is it set to 4096?
        Though I get the disappointment, the block size issue was a time bomb in the original 3.x NAS firmware (years before 2 TB drives were on the market).
ProSupport for Business
