aequus
May 30, 2018Aspirant
Volume Read Only - OS 6.9.3
Hi, after a reboot my volume is now read only. Disks are ok, everything is backuped what can i do to solve it? dmesg shows: 21.497390] md126: detected capacity change from 0 to 10001279549...
aequus
yes apps was dismounted, everything exect md0 and md1. In the end I have to (try to9 repair to avoid a new installation. What caused the error message "/dev/md127 busy or in use" amd what can i od?
May 30, 2018Guru - Experienced User
I'd still start with just check, because there are some targeted repair options that are considered safer.
I don't know what is giving you the device busy. Did you do a sync before umounting?
You could try doing a btrfs device scan first. If all else fails you could boot up in tech support mode, as that won't mount the data volume. Let me know if you need to try that.
