junox
Mar 15, 2016Aspirant
Volume scan failed to run properly - ReadyNAS Ultra 4
Dear NetGear Community, I can not find any volume on NAS and can not access any my data after received alert mail "Volume scan failed to run properly." from ReadyNAS. This link is the log of M...
- Mar 17, 2016
Hello JennC,
Thank you for your kindness support.
I'm afraid but you may need data recovery service, the file system must be a messed file system. If you have full backup you can factory reset with the new disk then restore the data.
Okay, I'll do factory reset. I give up to restore my data.
junox
JennC
Mar 16, 2016NETGEAR Employee Retired
Hello junox,
I'm afraid but you may need data recovery service, the file system must be a messed up file system. If you have full backup you can factory reset with the new disk then restore the data.
junox
Mar 17, 2016Aspirant
Hello JennC,
junox
