vrspectre's avatar
vrspectre
Apprentice
May 04, 2021
Volume schedule during peak usage
Running OS 6.10.1.
My scrub runs 3 times a year and it takes about a week to finish. Is it possible to schedule it so that the scrub uses less CPU during peak usage and runs full bore at night when nobody is using it?
  • StephenB's avatar
    vrspectre wrote:
    Running OS 6.10.1.
    It already is running at a background priority.  FWIW, I believe the performance impact is largely due to the continuous disk I/O.  I don't think CPU would be a major factor on an RN516 (which is what I think you have???).
    It is possible to run the commands via ssh. There is a way to pause/resume the BTRFS scrub. Pausing mdadm checkarray is supposed to be possible, but I've never tried it.
    • vrspectre's avatar
      vrspectre
      Apprentice
      One of the apps I have has a CPU usage which shows 100% cpu being used. I supposed I/O is probably also a bottle neck. basically i just want it to run at night and pause during the day.
      Do you know how i might pause it and resume it? would love to schedule it.
      • StephenB's avatar
        I don't know exactly what command is being used for the mdadm piece, and that would matter for this. mdgm might know.
        For the btrfs piece of it, you'd enter
        # btrfs scrub cancel /path
        to pause, and then later on use
        # btrfs scrub resume /path
        to resume it.  The status is saved in a file, and it will pick up from where it left off.
        You can see the status using
        # btrfs scrub status -d /path
ProSupport for Business
