komm_it
Feb 03, 2016Guide
Volumes Name Conflict (error code 1014020000)
Hiello, I'm running 3 x RAID1 Volumes on a RN31600. I needed to upgrade one of the Volume (DISK_1) to a bigger capacity but don't want to "Destroy" the volume in case something goes wrong in my...
- Feb 03, 2016
Hello komm_it,
I apologize but using the same volume name on 2 different volumes will not really work. They will conflict with each other if you do so that is why it won't work that way.
How about adding another character instead?
JennC
Feb 03, 2016NETGEAR Employee Retired
Hello komm_it,
- komm_itFeb 03, 2016Guide
Hello JennC
Thanks but it seems that, if I want to re-use the same Volume name, I'll have to "destroy" the previous volume in order to "free" the name.
I gess that it's what I'm going to do. I just wanted to avoid detroying the previous array in case the copy i made on an external USB disk fail.
Well, I will have to make a backup of the copy and then destroy the array. I can't take the risk to have only one copy of the data even for a few hours.
Thanks again for you answer.
Pascal
