Duov2
Jul 04, 2012Aspirant
Wake on lan on Readynas duo v2 cannot work
I have a readynas duo v2 with the latest firmware. However, if I shut it down using the shut down function on the dashboard, there is no way to power it on ( even if I hit the on switch) apart from un...
HERBIEO
Jul 05, 2012Aspirant
I use power timer and wol on my Duo v2 with 5.3.5 firmware with no problems at all, maybe you should try a OS reinstall,
Intructions here > http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
make sure you choose OS reinstall and not factory reset as that wipes your disks clean,
OS reinstall boot mode also resets some settings on your unit, such as Internet protocol settings and the administrator password, to defaults.
