Duov2
Jul 04, 2012Aspirant
Wake on lan on Readynas duo v2 cannot work
I have a readynas duo v2 with the latest firmware. However, if I shut it down using the shut down function on the dashboard, there is no way to power it on ( even if I hit the on switch) apart from un...
Charles_R
Jul 05, 2012Aspirant
Duov2 wrote: I have a readynas duo v2 with the latest firmware. However, if I shut it down using the shut down function on the dashboard, there is no way to power it on ( even if I hit the on switch) apart from unplugging it and plugging it again.
I have had the issue with several NV+ v2 and DUO v2 units. In my experience I can't wake it up over LAN or via the power button after x number of hours. Both appear to work fine for 12 or so hours... after that I have to pull the power cord/plug it back in to get powered up. Others have reported the same in a thread I started about the issue...
