Duov2
Jul 04, 2012Aspirant
Wake on lan on Readynas duo v2 cannot work
I have a readynas duo v2 with the latest firmware. However, if I shut it down using the shut down function on the dashboard, there is no way to power it on ( even if I hit the on switch) apart from un...
Charles_R
Jul 05, 2012Aspirant
HERBIEO wrote: I have power on scheduled 18.00 and power off 00.00 hours all'ways works, and i use wol maybe about once a week and all'ways works,
From my experience (half dozen different units) with Beta 5.3.5 through the release it is an issue that doesn't show up until the unit is offline for over 12 hours... at times longer. So based on one's use one might never see it... I have never had it work once offline for a day (or so) either via WOL or the power button. I don't use the scheduler for powering on/off so if that option plays a part I can't say.
