Duov2
Jul 04, 2012Aspirant
Wake on lan on Readynas duo v2 cannot work
I have a readynas duo v2 with the latest firmware. However, if I shut it down using the shut down function on the dashboard, there is no way to power it on ( even if I hit the on switch) apart from un...
mdgm-ntgr
Jul 07, 2012NETGEAR Employee Retired
If you download your logs and extract the contents of the zip file what does bios_ver.log look like?
