Duov2
Jul 04, 2012Aspirant
Wake on lan on Readynas duo v2 cannot work
I have a readynas duo v2 with the latest firmware. However, if I shut it down using the shut down function on the dashboard, there is no way to power it on ( even if I hit the on switch) apart from un...
Duov2
Jul 07, 2012Aspirant
U-Boot 1.1.4 (Feb 6 2012 - 14:40:46) Marvell version: 3.4.27
Netgear version: Uboot-1_1_4-NetgearDUOV3-V1008 If U-Boot Endiannes is going to change (LE->BE or BE->LE), Then Env parameters should be overriden..
