Duov2
Jul 04, 2012Aspirant
Wake on lan on Readynas duo v2 cannot work
I have a readynas duo v2 with the latest firmware. However, if I shut it down using the shut down function on the dashboard, there is no way to power it on ( even if I hit the on switch) apart from un...
mdgm-ntgr
Jul 07, 2012NETGEAR Employee Retired
I suggest you open a tech support (http://www.ReadyNAS.com/support) case and edit the thread title (subject of first post in the thread) to include your case number.
