Duov2
Jul 04, 2012Aspirant
Wake on lan on Readynas duo v2 cannot work
I have a readynas duo v2 with the latest firmware. However, if I shut it down using the shut down function on the dashboard, there is no way to power it on ( even if I hit the on switch) apart from unplugging it and plugging it again.
Furthermore, if I use the power down timer, when the unit powers down by itself at the set time, it cannot be woken up by WoL and I have to manually switch it on again. That defeats the purpose of WoL. I want to be able to wake up my unit if I need to use it and not wait until the set time on the power down timer.
Plus, I tried to WoL over the Internet with my unit connected to LAN, but it just does not work even though I have portfowarded udp port 7 and 9.
Help anyone? Anyone has the same problem?
I want to be able to set my unit to power down standby mode and be able to WoL over the Internet when I need it.
- SootchuckerAspirantHerbieo, the WOL is a feature I would like to use via readynas remote, to turn my NV+ V2 on remotely when I need to. Could you explain for a simpleton like me how I do that please ?
