mario_r
Oct 29, 2015Aspirant
web front end is not working anymore
After making some changes on my ReadyNAS 104 the web front end is not availiabe anymore. I have no ssh access to the system, a reboot does not help. What can I do to fix this?
Oct 29, 2015Guru - Experienced User
Do you still have access to the shares?
mario_r
Yes, no problem to access the shares. It seems like the apache is not working. Last time I worked on this gui I think I made an update for the Jenkins addon, so I think the apache is the problem, but as I have no ssh access I think I am not able to fix this on my own.
- StephenBOct 29, 2015Guru - Experienced User
The first step is to backup the shares, since there is a chance you'd need to rebuild the NAS.
You could try booting into tech support mode - not sure if the telnet log on was changed for OS 6.
- mario_rOct 29, 2015Aspirant
So, there is a way to access the NAS via Telnet in support mode? That should help me to restart the apache and maybe fix the issue. Is there a doc about telnet port and user/passwort anywhere?
I just followed this https://community.netgear.com/t5/Using-your-ReadyNAS/Solved-OS6-6-2-2-Frontview-gone-fixed-without-SSH/td-p/946050 tutorial and was able the remove the vhost entry which was the problem. Thanks for your help!
