renoir13
Nov 16, 2015Aspirant
WebDAV on ReadyNAS Duo v1 not responding to WAN connections
Hi, I set up WebDAV access on a ReadyNAS Duo v1 running firmware v.4.1.14. I followed the instructions as stated here, including installation of mentioned webdav patch. I configured a share to be...
Nov 16, 2015Guru - Experienced User
DId you try the android device's browser? That might give a clue.
- renoir13Nov 16, 2015Aspirant
Works just fine, after the usual self-signed certificate warning.
- StephenBNov 16, 2015Guru - Experienced User
Ok. So the connection is working fine.
Perhaps ES File Explorer is choking on the cert error??? Or a typo in its webdav server config???
I set it up to use ftps myself (which works fine, and is also encrypted).
StephenB wrote:Perhaps ES File Explorer is choking on the cert error??? Or a typo in its webdav server config???
No, this isn't the problem, unfortunately. As I mentioned before, I am able to establish a connection and transfer files with ES Explorer as long as I connect from LAN. The issue exists for WAN connections only. I suspect webdav is dropping every connection originating from any address range other than the lan's subnet. I have ssh access enabled; could you point me to any configuration file that define access restrictions based on IP addresses?
