renoir13
Nov 16, 2015Aspirant
WebDAV on ReadyNAS Duo v1 not responding to WAN connections
Hi, I set up WebDAV access on a ReadyNAS Duo v1 running firmware v.4.1.14. I followed the instructions as stated here, including installation of mentioned webdav patch. I configured a share to be...
Nov 16, 2015Guru - Experienced User
DId you try the android device's browser? That might give a clue.
renoir13
Works just fine, after the usual self-signed certificate warning.
- StephenBNov 16, 2015Guru - Experienced User
Ok. So the connection is working fine.
Perhaps ES File Explorer is choking on the cert error??? Or a typo in its webdav server config???
I set it up to use ftps myself (which works fine, and is also encrypted).
- renoir13Nov 16, 2015Aspirant
StephenB wrote:Perhaps ES File Explorer is choking on the cert error??? Or a typo in its webdav server config???
No, this isn't the problem, unfortunately. As I mentioned before, I am able to establish a connection and transfer files with ES Explorer as long as I connect from LAN. The issue exists for WAN connections only. I suspect webdav is dropping every connection originating from any address range other than the lan's subnet. I have ssh access enabled; could you point me to any configuration file that define access restrictions based on IP addresses?
renoir13 wrote:
I suspect webdav is dropping every connection originating from any address range other than the lan's subnet.If that were the case, then the Android browser wouldn't have been able to browse the share either. So this is confusing.
Perhaps a Netgear person can reply on the config question.
When I have a chance, I'll configure one of my Duo's shares to use webdav, and see if I can duplicate your problem on my phone.
