kevinb1
Jan 29, 2016Aspirant
What btrfs data compression format is used in NAS OS 6?
I was looking at the options for btrfs, and I can't remember what Netgear mentioning what type of data compression is used in their boxes. I've heard of both zlib (faster compresion) and LZO (mor...
Jan 30, 2016Guru - Experienced User
kevinb1 wrote:
.I've heard of both zlib (faster compresion) and LZO (more compression) being used in btrfs systems.
You have this backwards btw. zlib has higher compression ratios, and LZO is faster. https://btrfs.wiki.kernel.org/index.php/Compression#What_is_the_default_compression_method.3F
My RN202 uses zlib - if you are using ssh, you can see this by entering
btrfs property get /volumename/sharename
Unfortunately there is no way to see the compression ratio for a file. https://btrfs.wiki.kernel.org/index.php/FAQ#Can_I_find_out_compression_ratio_of_a_file.3F
Note bitrot protection must be enabled to create a compressed share.
