stevenestrada
Sep 16, 2018Aspirant
What happened to smbplus addon
Hello What happened to smblus? I upgraded the readynas os to 6.9.4, rebooted, logged on the gui, then hit the button to upgrade smbplus to 1.0.8 from 1.0.7. The addon disappreared off the screen with...
bedlam1
Sep 16, 2018Prodigy
It's on my GUI APPS available page using 6.9.4 and I just installed it as test.
Have you tried clearing your browser cache etc. or another browser?
- stevenestradaSep 16, 2018AspirantYeah I tried that So you can go to the available app page and see smbplus And don't get a usless error like this upgrading Sep 16, 2018 12:52:20 PM System: Cannot install application SMB Plus.
- bedlam1Sep 16, 2018Prodigy
No I didn't get those results (I also un-installed it succesfully)
If the app is still available and the upgrade bombed resulting in it disappearing off the installed and available pages, I guess I'll have to putty in and type something to get it back in. I tried. Not a clue how to fix it
# apt install smbplus Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: smbplus 0 upgraded, 1 newly installed, 0 to remove and 40 not upgraded. 1 not fully installed or removed. Need to get 179 kB of archives. After this operation, 580 kB of additional disk space will be used. Get:1 http://apt.readynas.com/packages/readynasos 6.9.4/apps amd64 smbplus amd64 1.0.8 [179 kB] Fetched 179 kB in 0s (7,998 kB/s) debconf: delaying package configuration, since apt-utils is not installed Selecting previously unselected package smbplus. (Reading database ... 20207 files and directories currently installed.) Preparing to unpack .../smbplus_1.0.8_amd64.deb ... Unpacking smbplus (1.0.8) ... Setting up rsyslog-mysql (8.4.2-1+deb8u2) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dbconfig-common: writing config to /etc/dbconfig-common/rsyslog-mysql.conf dpkg: error processing package rsyslog-mysql (--configure): subprocess installed post-installation script returned error exit status 10 Setting up smbplus (1.0.8) ... Errors were encountered while processing: rsyslog-mysql E: Sub-process /usr/bin/dpkg returned an error code (1)
