stevenestrada
Sep 16, 2018Aspirant
What happened to smbplus addon
Hello What happened to smblus? I upgraded the readynas os to 6.9.4, rebooted, logged on the gui, then hit the button to upgrade smbplus to 1.0.8 from 1.0.7. The addon disappreared off the screen with...
stevenestrada
If the app is still available and the upgrade bombed resulting in it disappearing off the installed and available pages, I guess I'll have to putty in and type something to get it back in. I tried. Not a clue how to fix it
# apt install smbplus Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: smbplus 0 upgraded, 1 newly installed, 0 to remove and 40 not upgraded. 1 not fully installed or removed. Need to get 179 kB of archives. After this operation, 580 kB of additional disk space will be used. Get:1 http://apt.readynas.com/packages/readynasos 6.9.4/apps amd64 smbplus amd64 1.0.8 [179 kB] Fetched 179 kB in 0s (7,998 kB/s) debconf: delaying package configuration, since apt-utils is not installed Selecting previously unselected package smbplus. (Reading database ... 20207 files and directories currently installed.) Preparing to unpack .../smbplus_1.0.8_amd64.deb ... Unpacking smbplus (1.0.8) ... Setting up rsyslog-mysql (8.4.2-1+deb8u2) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dbconfig-common: writing config to /etc/dbconfig-common/rsyslog-mysql.conf dpkg: error processing package rsyslog-mysql (--configure): subprocess installed post-installation script returned error exit status 10 Setting up smbplus (1.0.8) ... Errors were encountered while processing: rsyslog-mysql E: Sub-process /usr/bin/dpkg returned an error code (1)
Sep 17, 2018Guru - Experienced User
Do you also have rsyslog installed?
- stevenestradaSep 17, 2018Aspirantrsyslog? I though I got rid of that last year it didn't work from day one is that the reason smbplus upgrade messed up? whats the fix
- StephenBSep 17, 2018Guru - Experienced User
stevenestrada wrote:
is that the reason smbplus upgrade messed up? whats the fixWell, the error message points in that direction
... dpkg: error processing package rsyslog-mysql (--configure)I'm not seeing any reference to that package in my own logs. You could try uninstalling that from ssh.
That didn't work out too well.
I'm just going around in circles typing in commands
But smpplus 1.0.8 popped up on the installed apps gui with the picture gone.
And this error: System: Cannot uninstall application SMB Plus.
cifs access seems to be working fine
Seems I got a lot of cleaning up to do before the next os upgrade. Any clue how to fix this mess?
# apt-get remove rsyslog Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: libmysqlclient18 mysql-common Use 'apt autoremove' to remove them. The following packages will be REMOVED: rsyslog rsyslog-mysql 0 upgraded, 0 newly installed, 2 to remove and 40 not upgraded. 1 not fully installed or removed. After this operation, 2,109 kB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 20278 files and directories currently installed.) Removing rsyslog-mysql (8.4.2-1+deb8u2) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dpkg: error processing package rsyslog-mysql (--remove): subprocess installed pre-removal script returned error exit status 10 debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dbconfig-common: flushing administrative password dpkg: error while cleaning up: subprocess installed post-installation script returned error exit status 10 dpkg: rsyslog: dependency problems, but removing anyway as you requested: rsyslog-mysql depends on rsyslog (= 8.4.2-1+deb8u2). Removing rsyslog (8.4.2-1+deb8u2) ... Errors were encountered while processing: rsyslog-mysql E: Sub-process /usr/bin/dpkg returned an error code (1) # apt-get --purge remove rsyslog Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: rsyslog-mysql : Depends: rsyslog (= 8.4.2-1+deb8u2) but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). # apt-get -f install Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following additional packages will be installed: rsyslog Suggested packages: rsyslog-mongodb rsyslog-doc rsyslog-gnutls rsyslog-gssapi rsyslog-relp The following NEW packages will be installed: rsyslog 0 upgraded, 1 newly installed, 0 to remove and 40 not upgraded. 1 not fully installed or removed. Need to get 0 B/546 kB of archives. After this operation, 1,878 kB of additional disk space will be used. Do you want to continue? [Y/n] y debconf: delaying package configuration, since apt-utils is not installed Selecting previously unselected package rsyslog. (Reading database ... 20232 files and directories currently installed.) Preparing to unpack .../rsyslog_8.4.2-1+deb8u2_amd64.deb ... Unpacking rsyslog (8.4.2-1+deb8u2) ... Processing triggers for systemd (230-7~bpo8+2.netgear2) ... Setting up rsyslog (8.4.2-1+deb8u2) ... Setting up rsyslog-mysql (8.4.2-1+deb8u2) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dbconfig-common: writing config to /etc/dbconfig-common/rsyslog-mysql.conf dpkg: error processing package rsyslog-mysql (--configure): subprocess installed post-installation script returned error exit status 10 Errors were encountered while processing: rsyslog-mysql E: Sub-process /usr/bin/dpkg returned an error code (1)
