stevenestrada
Sep 16, 2018Aspirant
What happened to smbplus addon
Hello What happened to smblus? I upgraded the readynas os to 6.9.4, rebooted, logged on the gui, then hit the button to upgrade smbplus to 1.0.8 from 1.0.7. The addon disappreared off the screen with...
stevenestrada
Sep 17, 2018Aspirant
rsyslog?
I though I got rid of that last year
it didn't work from day one
is that the reason smbplus upgrade messed up?
whats the fix
Sep 17, 2018Guru - Experienced User
stevenestrada wrote:
is that the reason smbplus upgrade messed up? whats the fix
Well, the error message points in that direction
Setting up rsyslog-mysql
... dpkg: error processing package rsyslog-mysql (--configure)
I'm not seeing any reference to that package in my own logs. You could try uninstalling that from ssh.
- stevenestradaSep 17, 2018Aspirant
That didn't work out too well.
I'm just going around in circles typing in commands
But smpplus 1.0.8 popped up on the installed apps gui with the picture gone.
And this error: System: Cannot uninstall application SMB Plus.
cifs access seems to be working fine
Seems I got a lot of cleaning up to do before the next os upgrade. Any clue how to fix this mess?
# apt-get remove rsyslog Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: libmysqlclient18 mysql-common Use 'apt autoremove' to remove them. The following packages will be REMOVED: rsyslog rsyslog-mysql 0 upgraded, 0 newly installed, 2 to remove and 40 not upgraded. 1 not fully installed or removed. After this operation, 2,109 kB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 20278 files and directories currently installed.) Removing rsyslog-mysql (8.4.2-1+deb8u2) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dpkg: error processing package rsyslog-mysql (--remove): subprocess installed pre-removal script returned error exit status 10 debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dbconfig-common: flushing administrative password dpkg: error while cleaning up: subprocess installed post-installation script returned error exit status 10 dpkg: rsyslog: dependency problems, but removing anyway as you requested: rsyslog-mysql depends on rsyslog (= 8.4.2-1+deb8u2). Removing rsyslog (8.4.2-1+deb8u2) ... Errors were encountered while processing: rsyslog-mysql E: Sub-process /usr/bin/dpkg returned an error code (1) # apt-get --purge remove rsyslog Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: rsyslog-mysql : Depends: rsyslog (= 8.4.2-1+deb8u2) but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). # apt-get -f install Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following additional packages will be installed: rsyslog Suggested packages: rsyslog-mongodb rsyslog-doc rsyslog-gnutls rsyslog-gssapi rsyslog-relp The following NEW packages will be installed: rsyslog 0 upgraded, 1 newly installed, 0 to remove and 40 not upgraded. 1 not fully installed or removed. Need to get 0 B/546 kB of archives. After this operation, 1,878 kB of additional disk space will be used. Do you want to continue? [Y/n] y debconf: delaying package configuration, since apt-utils is not installed Selecting previously unselected package rsyslog. (Reading database ... 20232 files and directories currently installed.) Preparing to unpack .../rsyslog_8.4.2-1+deb8u2_amd64.deb ... Unpacking rsyslog (8.4.2-1+deb8u2) ... Processing triggers for systemd (230-7~bpo8+2.netgear2) ... Setting up rsyslog (8.4.2-1+deb8u2) ... Setting up rsyslog-mysql (8.4.2-1+deb8u2) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dbconfig-common: writing config to /etc/dbconfig-common/rsyslog-mysql.conf dpkg: error processing package rsyslog-mysql (--configure): subprocess installed post-installation script returned error exit status 10 Errors were encountered while processing: rsyslog-mysql E: Sub-process /usr/bin/dpkg returned an error code (1)
- StephenBSep 17, 2018Guru - Experienced User
Did you try
apt-get --purge remove rsyslog-mysql
Unfortunately the best way to get a clean OS back is to do a factory reset and restore all the data from backup.
Yes I did.
# apt-get --purge remove rsyslog-mysql Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: libmysqlclient18 mysql-common Use 'apt autoremove' to remove them. The following packages will be REMOVED: rsyslog-mysql* 0 upgraded, 0 newly installed, 1 to remove and 40 not upgraded. 1 not fully installed or removed. After this operation, 231 kB disk space will be freed. Do you want to continue? [Y/n] Y (Reading database ... 20232 files and directories currently installed.) Removing rsyslog-mysql (8.4.2-1+deb8u2) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dpkg: error processing package rsyslog-mysql (--purge): subprocess installed pre-removal script returned error exit status 10 debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dbconfig-common: flushing administrative password dpkg: error while cleaning up: subprocess installed post-installation script returned error exit status 10 Errors were encountered while processing: rsyslog-mysql E: Sub-process /usr/bin/dpkg returned an error code (1) # apt-get --purge remove rsyslog-mysql -f Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: libmysqlclient18 mysql-common Use 'apt autoremove' to remove them. The following packages will be REMOVED: rsyslog-mysql* 0 upgraded, 0 newly installed, 1 to remove and 40 not upgraded. 1 not fully installed or removed. After this operation, 231 kB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 20232 files and directories currently installed.) Removing rsyslog-mysql (8.4.2-1+deb8u2) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dpkg: error processing package rsyslog-mysql (--purge): subprocess installed pre-removal script returned error exit status 10 debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dbconfig-common: flushing administrative password dpkg: error while cleaning up: subprocess installed post-installation script returned error exit status 10 Errors were encountered while processing: rsyslog-mysql E: Sub-process /usr/bin/dpkg returned an error code (1) # apt autoremove -f Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 40 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up rsyslog-mysql (8.4.2-1+deb8u2) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline dbconfig-common: writing config to /etc/dbconfig-common/rsyslog-mysql.conf dpkg: error processing package rsyslog-mysql (--configure): subprocess installed post-installation script returned error exit status 10 Errors were encountered while processing: rsyslog-mysql E: Sub-process /usr/bin/dpkg returned an error code (1)
Don't they have a kb or something to step though cleaning things up?
If wiping put all my data and starting from scratch is the answer to fix one lousy addon that wont install/uninstall, this NAS belongs in the garbage. - StephenBSep 18, 2018Guru - Experienced User
Maybe try
# export DEBIAN_FRONTEND=noninteractive
# apt-get -yq --purge remove rsyslog-mysql
Paid support (my.netgear.com) can rebuild the OS from scratch w/o data loss, but there is no kb article on how to do that, and I don't know the details.
It would be useful for advanced users if it were documented, although I suspect there would also be less advanced users who would accidentally destroy their data when they attempted it. It'd be better if there was a script or boot menu option to do this (perhaps part of the new safe mode?)
FWIW, in my view the issue here is that that rsyslog install scripts weren't correct to begin with, and the app shouldn't have listed as an available app by Netgear.
