MrPhelps
Aug 17, 2012Aspirant
What happens in case of URE when recovering ?
Hi, I have a ReadyNAS NV+ with firmware v 4.1.7 configured in X-RAID. In the hypothetical event one of the disk crashes, and there is an URE when reconstructing the array after replacing the disk, ...
TeknoJnky
Aug 18, 2012Hero
to answer the question, it really depends on how the disk handles the ure and possibly whether its a read or write error.
worst case scenario, the disk freezes and causes a multiple disk failure and the loss of data, alternatively it could just hang the rebuild process causing a hard reboot to be done. At which point the rebuild process will resume, either repeating the freeze or possibly getting through the error, or an error being generated and the device going into tech support mode.
best case scenario, the error is on a write and the disk automagically reallocates to a new sector and continues on with the rebuild. These will typically be seen as 're-allocated sector count' errors in the smart diagnostics and error logs.
