paulinde
Jul 20, 2016Aspirant
What is a file "Versions"? 6.5.1
When I right click a file name within a share, I am seeing "Versions" as a choice. What are they and where did they come from? When I look at the snapshots for that share, I do not see any connecti...
- Jul 20, 2016Versions is based on Snapshots.
The Versions will show you the different versions of the file that are retained in the Snapshot. If the version of the file is the same (duplicates) it will not display that version of the file. It should help users fine the different versions of the files based on the snapshot without having to look at a bunch of duplicate files that retain the same content.
The versioning/changing of the files are checked in BTRFS.
Hopchen
Jul 20, 2016Prodigy
It is still controlled by the snapshots themselves.
I have a file in a share.
- I snapshot the share daily.
- I change file only once over 3 days.
Now, I have 3 snapshots, but only two versions. Makes sense right? As old snapshots are prunned out over time, older versions of the file will also disappear.
OOM-9
Jul 20, 2016NETGEAR Expert
