armornone
Sep 20, 2013Aspirant
Where can I download the firmware 4.1.12 for USB BOOT Drive.
Where can I download the firmware 4.1.12 to write on a USB boot drive? I think this is a different file then the normal 4.1.12 firmware. Thanks for your help.
armornone
mdgm wrote: See http://www.readynas.com/kb/faq/boot/how_can_i_perform_a_boot_recovery_using_a_usb_flash_device
Why do you need this? Boot Recovery is rarely needed. Usually the problem is something else.
Ok, here is the problem.
I upgraded my firmware from 4.1.8 to 4.1.12 and everything was fine. Then I did a factory reset process like I normally have done, I went into the RAIDar software, "click setup", navigated though some pages to select " X-raid"then it tells me that it will create the volume however nothing happens beyond this point.
Normally RAIDar will having the volume light flashing blue I think and it will start the process and/or reset and stuff...
However, it just said " click setup" on the RAIDar and the unit I think said something like " waiting for RAIDar"
I keep clicking though this process over and over again but it won't seem to take to the readynas( NV+).
So it seem like maybe something is wrong. Maybe a bad drive? I am not sure.
