nsne
Dec 17, 2016Virtuoso
Why am I getting "sudo: command not found"?
I'm trying to update LMS on my 314 via the command line: sudo dpkg -i /var/lib/squeezeboxserver/cache/updates/logitechmediaserver_7.9.0[...]amd64.deb This method used to work just fine, but t...
- Dec 18, 2016
Just leave the sudo out, you shouldn't need it since you are logged in as root.
Dec 18, 2016Guru - Experienced User
