teddyb
May 08, 2017Aspirant
Why is Volume Size below calculated?
Hi, I just had to rebuild a chassis (EDA500) from scratch. I did the following: 1. Powered down. 2. Removed drives 3. Deleted partitions 4. Inserted drives 5. Powered on 6. Selected new...
- May 15, 2017That's fine.
If you don't have any unused drive in the chassis and only one volume per chassis, then turn on X-RAID, and your volume should expand (vertical expansion).
Retired_Member
May 08, 2017
The difference come from confusing decimal and binary prefixes. Harddisk manufactures prefer decimal, your NAS is using binary.
| Prefixes for multiples of bits (bit) or bytes (B)
- teddybMay 08, 2017Aspirant
Thanks. I get the reasoning you mentioned, but the difference is very large and even larger on the EDA500 than that of the DATA volume. And, my other EDA500 with 3-3-3-3-3 is actually larger...
That doesn't add up to me.
- StephenBMay 08, 2017Guru - Experienced User
Windows also uses binary (TiB).
teddyb wrote:
However, I did 8-8-6-6-6 TB WD Red drives and the interface says total size of 21.81 TB versus 23.157 TB calculated. My DATA volume has a similar problem with 8-8-8-8-8-6 and 32.72 TB versus 33.848 calculated.
Try entering 21.81 TiB in TB into google search, it will convert the units for you. You should see 23.98 TB
Similarly entering 32.72 TiB in TB will give you 35.98 TiB
Can you check that you typed the disk configuration info correctly? With XRAID single redundancy you should be getting 26TB and 38TB. Dual redundancy would be 16 TB and 30 TB.
The configurations are correct at 8-8-8-8-8-6 and 8-8-6-6-6. Both calculate a higher expected size (kossboss calculator) than I have showing up.
Any ideas why tho?
I recall seeing some bugs in that calculator, but it's been a long time since I looked at it.
I can only tell you what the sizes should be with XRAID. Overhead from the OS partition, etc is negligible. The rule for single redundancy is "sum the disks and subtract the largest".
- 2x8TB+3x6TB gives you 26 TB. The NAS would show ~23.6 TiB for the volume size.
- 5x8TB+1x6TB gives you 38 TB. The NAS would show ~34.5 TiB.
It looks to me like both volumes are about 2 TB too small. What is the expansion history?
